はじめに
This is a guide on how to remove the hard drive on this lap top. Reasons for removal of the hard drive are the current one has stopped working, or to get upgrade to a more improved hard drive.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
コメントを追加する
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
コメントを追加する
The hard drive is located on the bottom of the laptop on the left hand side.
  • The hard drive is located on the bottom of the laptop on the left hand side.
コメントを追加する
Remove the two scores on the cover with the screwdriver specified.
  • Remove the two scores on the cover with the screwdriver specified.
コメントを追加する
Lift off the cover with the plastic opener.
  • Lift off the cover with the plastic opener.
コメントを追加する
Unscrew the one screw holding the hard drive in place with the same screw driver.
  • Unscrew the one screw holding the hard drive in place with the same screw driver.
コメントを追加する
Slide the hard drive up and remove it from the laptop.
  • Slide the hard drive up and remove it from the laptop.
コメントを追加する
まとめ
2 の人々がこのガイドを完成させました。
Kyle
メンバー登録日: 2014年03月11日
622 ポイント
10のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Calaway Spring 2014 UMass Dartmouth, Team 3-2, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S3G2
4 メンバー
18のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 239
