メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
With a Phillips #0 screwdriver, the hard drive can easily be replaced.
パーツ
パーツは指定されていません。
  1. Unlock the tab located in the top left corner of the netbook. The red tab indicated that the battery has been properly unlocked. Remove the battery.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. The hard drive is located under this cover.
    • The hard drive is located under this cover.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver. Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  5. Use a plastic opening tool to lift the cover. Use a plastic opening tool to lift the cover.
    • Use a plastic opening tool to lift the cover.
  6. Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  7. Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up. Lift the silver cover; this will expose the hard drive. Lift the silver cover; this will expose the hard drive.
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
終わりに
Lydia Benjock
メンバー登録日: 2013年10月18日
1,189 ポイント
10のガイドは作成済み
チーム
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G3
3 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,254
