メインコンテンツにスキップ
Gateway KAV60 LT2016U Cooling Fan Replacement
必要な工具と部品
  1. Gateway KAV60 LT2016U Cooling Fan Replacement, Battery: 手順 1、 3の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement, Battery: 手順 1、 3の画像 2 Gateway KAV60 LT2016U Cooling Fan Replacement, Battery: 手順 1、 3の画像 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Cooling Fan Replacement, Upper Cover: 手順 2、 1の画像 1
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 3、 2の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 3、 2の画像 2
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 4、 3の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 4、 3の画像 2 Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 4、 3の画像 3
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 5、 1の画像 1
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 6、 2の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 6、 2の画像 2
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
  7. Gateway KAV60 LT2016U Cooling Fan Replacement, WiFi Card: 手順 7、 2の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement, WiFi Card: 手順 7、 2の画像 2
    • The WiFi card is shown here.
    • Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
  8. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 8、 2の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 8、 2の画像 2
    • Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
  9. Gateway KAV60 LT2016U Cooling Fan Replacement, Motherboard: 手順 9、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the four (4) 5mm screws holding the motherboard in place.
  10. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 10、 1の画像 1
    • Remove the motherboard by lifting it gently from the bottom cover.
    • This image is the rear view of the motherboard.
  11. Gateway KAV60 LT2016U Cooling Fan Replacement, Cooling Fan: 手順 11、 1の画像 1
    • Begin with the motherboard of the computer, as shown here.
  12. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 12、 1の画像 1
    • Using the #00 Phillips head screwdriver, remove all four (4) screws marked here.
  13. Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 13、 2の画像 1 Gateway KAV60 LT2016U Cooling Fan Replacement: 手順 13、 2の画像 2
    • Gently disconnect the fan cable from the motherboard by pulling on the connection until it slips out.
    • The fan should then be fully disconnected from the motherboard and ready for replacement.
終わりに
3 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Brandon Bowman
メンバー登録日: 10/18/13
144 ポイント
1ガイドが承認済み
チーム
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G3
3 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 982
