Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
Follow the black ribbon cable to the connector and gently pull straight up.
Remove the five screws with a Phillips #0 screwdriver.
The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
Lift the hinge covers along the outer edges with the spudger until they are released.
Slide the release and push the button to eject the drive.
Remove the drive.
When reinserting the drives, be sure to put them in the original slot to avoid interface conflicts.
Insert your spudger between the upper and lower case at the drive bay closest to the battery.
Carefully and slowly go around the entire case, unseating all plastic clips holding the upper and lower cases together.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
