メインコンテンツにスキップ
Gateway 600YG2 Top Case Replacement
必要な工具と部品
  1. Gateway 600YG2 Top Case Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 Top Case Replacement: 手順 2、 1の画像 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 Top Case Replacement, Power Button Panel: 手順 3、 1の画像 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 Top Case Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove the 5 screws holding the keyboard in place.
  5. Gateway 600YG2 Top Case Replacement: 手順 5、 2の画像 1 Gateway 600YG2 Top Case Replacement: 手順 5、 2の画像 2
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Gateway 600YG2 Top Case Replacement, LCD: 手順 6、 1の画像 1
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  7. Gateway 600YG2 Top Case Replacement: 手順 7、 1の画像 1
    • Gently unplug the LCD from the system board.
  8. Gateway 600YG2 Top Case Replacement: 手順 8、 1の画像 1
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  9. Gateway 600YG2 Top Case Replacement: 手順 9、 1の画像 1
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
  10. Gateway 600YG2 Top Case Replacement, CD/DVD or Floppy drives: 手順 10、 1の画像 1
    • Slide the release and push the button to eject the drive.
    • Remove the drive.
    • When reinserting the drives, be sure to put them in the original slot to avoid interface conflicts.
  11. Gateway 600YG2 Top Case Replacement, Top Case: 手順 11、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
  12. Gateway 600YG2 Top Case Replacement: 手順 12、 1の画像 1
    • Remove the two indicated screws.
  13. Gateway 600YG2 Top Case Replacement: 手順 13、 1の画像 1
    • Remove the four screws from the back of the case.
  14. Gateway 600YG2 Top Case Replacement: 手順 14、 1の画像 1
    • Potential for device damage: Failure to properly do this step will damage your mouse pad ribbon.
    • Lift the plug holding the mouse ribbon about 1/16 inch or until it stops
    • Remove the ribbon.
  15. Gateway 600YG2 Top Case Replacement: 手順 15、 1の画像 1
    • Insert your spudger between the upper and lower case at the drive bay closest to the battery.
    • Carefully and slowly go around the entire case, unseating all plastic clips holding the upper and lower cases together.
  16. Gateway 600YG2 Top Case Replacement: 手順 16、 1の画像 1
    • Lift the upper case about 1/4 inch.
    • At the rear of the case is one last connecting wire. Unplug it and remove the upper case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Elizabeth Mazer
メンバー登録日: 10/14/10
78 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S20G10
3 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,869
