はじめに
removal of the system board
必要な工具と部品
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Slide the release and push the button to eject the drive.
Remove the drive.
Unscrew 1 captive screw holding hard drive cover on.
slide hard drive to the right and remove.
for detailed pictures and info go to Gateway Support
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Unscrew the four captive screws.
Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
