はじめに
This step-by-step guide will show you how to replace gas grill ceramic briquettes. In this guide, we'll walk you through each stage of the replacement process, from preparing your grill for maintenance to safely installing the new ceramic briquettes.
During this guide make sure you read through carefully and complete the steps with caution. Make sure grill is not on and if it was recently used wait for it to cool down before proceeding with this guide.
This step-by-step guide is necessary if your ceramic briquettes are unusable.
The only tool you will need is in step 5, it will require you to use a Phillips head screwdriver.
必要な工具と部品
Carefully remove entire ceramic briquette casing from above the stainless steel burner.
Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
Take 16 new ceramic briquettes out and carefully align them inside the casing.
3 の人々がこのガイドを完成させました。
