メインコンテンツにスキップ
Gas Grill Ceramic Briquettes Replacement
必要な工具と部品
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: 手順 1、 3の画像 1 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: 手順 1、 3の画像 2 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: 手順 1、 3の画像 3
    • Carefully lift grill plate located above briquettes
    • Make sure the gas grill is off and the propane is turned off before removing the grill plate
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: 手順 2、 3の画像 1 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: 手順 2、 3の画像 2 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: 手順 2、 3の画像 3
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: 手順 3、 3の画像 1 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: 手順 3、 3の画像 2 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: 手順 3、 3の画像 3
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
    • A small container is recommended to keep the screws together
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: 手順 4、 3の画像 1 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: 手順 4、 3の画像 2 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: 手順 4、 3の画像 3
    • Using your hands, gently unscrew washers from the back of the casing.
    • A small container is recommended to keep the washers together
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: 手順 5、 3の画像 1 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: 手順 5、 3の画像 2 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: 手順 5、 3の画像 3
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: 手順 6、 1の画像 1
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: 手順 7、 1の画像 1
    • Take 16 new ceramic briquettes out and carefully align them inside the casing.
    • Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
emma
メンバー登録日: 01/27/16
173 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016人のメンバー
USFSM-STEWART-S16S1G3
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 26
今までの合計 3,633
