はじめに
This guide will explain how to replace the batteries of the Garmin vívofit 2 device. A Phillips #00 screwdriver and two replacement CR1632 Batteries will be needed. The process is straightforward and there are no hazards involved.
必要な工具と部品
Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
With the cover removed, take out the two batteries currently in the device. Take note of which side of the battery is facing which way in the device. Battery removal can usually be accomplished with your fingers. If not, carefully use a nylon spudger to pull up one edge of the battery, allowing you to remove that battery.
ある他の人がこのガイドを完成しました。
