メインコンテンツにスキップ
Garmin nuvi 2460 LMT Battery Replacement
必要な工具と部品
  1. Garmin nuvi 2460 LMT Battery Replacement, Back Cover: 手順 1、 2の画像 1 Garmin nuvi 2460 LMT Battery Replacement, Back Cover: 手順 1、 2の画像 2
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Battery Replacement: 手順 2、 1の画像 1
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Battery Replacement: 手順 3、 1の画像 1
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Battery Replacement: 手順 4、 1の画像 1
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Battery Replacement, Battery: 手順 5、 1の画像 1
    • Using a pair of tweezers, grab the connecting wires and lift the terminal from the motherboard.
    • Avoid contacting battery terminals with metallic objects.
  6. Garmin nuvi 2460 LMT Battery Replacement: 手順 6、 1の画像 1
    • Pry the battery out of the back cover using a plastic opening tool.
    • Work the edges and apply force when removing the battery, as it will be glued down.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ricardo Audain
メンバー登録日: 09/07/16
671 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 6-4, Remmell Fall 2016 USF Tampa, Team 6-4, Remmell Fall 2016人のメンバー
USFT-REMMELL-F16S6G4
4 メンバー
7のガイドは作成済み
4 件のコメント
Can someone give me the close picture of motherboard area near usb charger. I have problems with charging device. I think one chip burned.
Thanks
Marko Vodenik - 返信
The T10 Torx screwdriver mentioned in this article and sold by IFixit (product number IF 145-080-4) is too big and does not fit the much smaller screws on the Garmin 2460. I wasted around £10 on a screwdriver that does not do the job!
Julian Renselar - 返信
1. Mine cover screws take a Torx T5. Bought a kit with all sizes (plus some other handy tiny electronic tools)on Amazon for $6.00 US.
2. The twisted wires from the back cover to the circuit board may not have a connector. The wire in mine was secured to the circuit board with two molecule-sized spots of solder which, of course, broke loose as soon as I opened the cover, stretching the too-short wire to its limit. I don’t know the funtion of this pair of small, twisted wires. They go from the circuit board to a slit opening in the back cover. Maybe a microphone for the bluetooth?? With no way to re-solder the two barely visible spots, I taped the wire out of the way and closed the unit back up. GPS functions all still work. Haven’t tried the bluetooth…I don’t use it anyway.
Michael - 返信
Sounds easy until you try to reconnect the tape connector to the motherboard. You need the eyes of an eagle, the luck of the Irish, and the patience of Job to remake that connection.
Ed Selby - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 32
今までの合計 5,507
