メインコンテンツにスキップ
Garmin eTrex Vista H Replacing Antenna Replacement
必要な工具と部品
  1. Garmin eTrex Vista H Replacing Antenna Replacement, Removing Battery: 手順 1、 1の画像 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 2、 1の画像 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 3、 2の画像 1 Garmin eTrex Vista H Replacing Antenna Replacement: 手順 3、 2の画像 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H Replacing Antenna Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: 手順 4、 2の画像 1 Garmin eTrex Vista H Replacing Antenna Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: 手順 4、 2の画像 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 5、 3の画像 1 Garmin eTrex Vista H Replacing Antenna Replacement: 手順 5、 3の画像 2 Garmin eTrex Vista H Replacing Antenna Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 6、 1の画像 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 7、 2の画像 1 Garmin eTrex Vista H Replacing Antenna Replacement: 手順 7、 2の画像 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H Replacing Antenna Replacement, Disassembling Garmin eTrex Vista H Motherboard: 手順 8、 1の画像 1
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 9、 1の画像 1
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H Replacing Antenna Replacement: 手順 10、 2の画像 1 Garmin eTrex Vista H Replacing Antenna Replacement: 手順 10、 2の画像 2
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
  11. Garmin eTrex Vista H Replacing Antenna Replacement, Replacing Antenna: 手順 11、 1の画像 1
    • Locate antenna on the back of the motherboard.
    • In order to replace the antennaa you have to purchase a new motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Taylor Hershey
メンバー登録日: 10/05/10
12 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G30
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 16
今までの合計 4,550
