パーツ
パーツは必要ありません。
  1. Use a plastic spudger tool to remove the plastic frame.
    • Use a plastic spudger tool to remove the plastic frame.
    • Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
  2. Use a phillips head screw driver to remove all four screws in the corners around the screen.
    • Use a phillips head screw driver to remove all four screws in the corners around the screen.
    • Set the screws aside for later.
    • Gently pull from both ends to separate the front panel from the back.
    • Do not force the pieces apart wider than the length of the connecting wires or you will damage the wiring.
    • Locate the white wire clip. Gently unplug it using either your fingers or tweezers.
    • Carefully expose both halves of the device.
    • Be sure to not pull the two halves apart too hard to avoid damaging the black wire.
まとめ
Your device should be ready to use once more.
2 の人々がこのガイドを完成させました。
Adrian Leon
メンバー登録日: 2010年10月07日
169 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G1
3 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,784
