メインコンテンツにスキップ
Garmin Nuvi 680 Motherboard Replacement
必要な工具と部品
  1. Garmin Nuvi 680 Motherboard Replacement, Outer Case: 手順 1、 1の画像 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Motherboard Replacement: 手順 3、 1の画像 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Motherboard Replacement: 手順 4、 2の画像 1 Garmin Nuvi 680 Motherboard Replacement: 手順 4、 2の画像 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Motherboard Replacement: 手順 6、 2の画像 1 Garmin Nuvi 680 Motherboard Replacement: 手順 6、 2の画像 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Motherboard Replacement, Antenna: 手順 7、 2の画像 1 Garmin Nuvi 680 Motherboard Replacement, Antenna: 手順 7、 2の画像 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Garmin Nuvi 680 Motherboard Replacement, Screen Wiring: 手順 8、 1の画像 1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Garmin Nuvi 680 Motherboard Replacement: 手順 9、 2の画像 1 Garmin Nuvi 680 Motherboard Replacement: 手順 9、 2の画像 2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
  10. Garmin Nuvi 680 Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Use a PH1 sized Philips screwdriver to remove the two screws shown.
    • These screws are 6.88 mm long
  11. Garmin Nuvi 680 Motherboard Replacement: 手順 11、 2の画像 1 Garmin Nuvi 680 Motherboard Replacement: 手順 11、 2の画像 2
    • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
    • Use a spudger to lift the edge of the motherboard.
  12. Garmin Nuvi 680 Motherboard Replacement: 手順 12、 1の画像 1
    • Gently unplug the cable for the battery
    • Gently unplug the cable for the speaker.
  13. Garmin Nuvi 680 Motherboard Replacement: 手順 13、 1の画像 1
    • Lift the motherboard out of the outer case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Chris Marzano
メンバー登録日: 01/20/11
968 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 5-22, Amido Winter 2011 Cal Poly, Team 5-22, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G22
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 3,619
