はじめに
Here are a few easy steps on how to correctly remove the motherboard so a new one can be installed.
必要な工具と部品
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
ある他の人がこのガイドを完成しました。
コメント 1 件
Do you know if there is any point on the motherboard where you could attach an external antenna? Or is the internal antenna removable to be replaced with an external or hacked to connect via a cable run to the outside of the device?
Did you happen to take a picture of the underside of the motherboard?
Thanks!
