メインコンテンツにスキップ
Garmin Nuvi 2797LMT Battery Replacement
必要な工具と部品
  1. Garmin Nuvi 2797LMT Battery Replacement, Battery: 手順 1、 1の画像 1
    • Before you begin make sure to turn off your GPS.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT Battery Replacement: 手順 2、 3の画像 1 Garmin Nuvi 2797LMT Battery Replacement: 手順 2、 3の画像 2 Garmin Nuvi 2797LMT Battery Replacement: 手順 2、 3の画像 3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT Battery Replacement: 手順 3、 2の画像 1 Garmin Nuvi 2797LMT Battery Replacement: 手順 3、 2の画像 2
    • With the device open, locate the battery with its wire connector plugged into the motherboard. Now delicately detach the battery connector from the center by inserting a spudger underneath the power wire and lift up.
  4. Garmin Nuvi 2797LMT Battery Replacement: 手順 4、 1の画像 1
    • Now using the small plastic opening tool, pry the battery up from the sides.
    • The battery has been attached with strong adhesive so you will need to use a little bit of force when prying it out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
baileykaytar
メンバー登録日: 10/13/15
366 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 2-6, Blackburne Fall 2015 Sam Houston State, Team 2-6, Blackburne Fall 2015人のメンバー
SHSU-BLACKBURNE-F15S2G6
3 メンバー
4のガイドは作成済み
3 件のコメント
Your sub-par tools broke when following the directions exactly. Last time I'll be purchasing any of your items, and Ill be disputing the charges on my card for this kit.
Game Science - 返信
Thanks.
But before I get going, which model or type of battery do I need. Garmin does not seem to sell them separately as far as I can see.
GregM
cagmccarry2 - 返信
Instructions very lacking. To replace the battery go to https://www.youtube.com/watch?v=OcoZC2Fk.... Much, much better instructions.
allen1 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 2,345
