メインコンテンツにスキップ
Garmin Nuvi 2689LMT Speaker Replacement
必要な工具と部品
  1. Garmin Nuvi 2689LMT Speaker Replacement, Main Circuit Board: 手順 1、 1の画像 1
    • Begin by removing the stand by depressing the tab and rocking the round interface back toward you, pulling it away from the Garmin unit.
  2. Garmin Nuvi 2689LMT Speaker Replacement: 手順 2、 1の画像 1
    • Remove the four, 4mm hex screws at the four corners of the device using a T5 bit.
  3. Garmin Nuvi 2689LMT Speaker Replacement: 手順 3、 1の画像 1
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams, the one on top is artificial.
    • Pry open the seam with a prying tool.
  4. Garmin Nuvi 2689LMT Speaker Replacement: 手順 4、 1の画像 1
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the spudger into the unit.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689LMT Speaker Replacement: 手順 5、 1の画像 1
    • Do not attempt to separate the unit until all the tabs have been separated. Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689LMT Speaker Replacement: 手順 6、 1の画像 1
    • The battery is connected to the main circuit board via two wires, red and green in color, and is attached with a white connector.
    • Detach with a pry tool.
  7. Garmin Nuvi 2689LMT Speaker Replacement: 手順 7、 1の画像 1
    • The white battery is attached to the casing with an adhesive. Separate it with a prying tool.
    • Removing the battery protects it from damage and gives you more room to work.
  8. Garmin Nuvi 2689LMT Speaker Replacement: 手順 8、 2の画像 1 Garmin Nuvi 2689LMT Speaker Replacement: 手順 8、 2の画像 2
    • Remove the four, 4mm hex screws with a T5 bit.
    • These are located near the four corners of the main circuit board, as shown.
  9. Garmin Nuvi 2689LMT Speaker Replacement: 手順 9、 1の画像 1
    • Carefully pick up and remove the main circuit board from the device’s plastic casing.
  10. Garmin Nuvi 2689LMT Speaker Replacement: 手順 10、 1の画像 1
    • Remove the speaker - located on the device as shown - from the plastic casing using a prying tool. Use the prying tool around the entire rim of the speaker to ensure a clean removal.
  11. Garmin Nuvi 2689LMT Speaker Replacement, Speaker: 手順 11、 1の画像 1
    • Tape the main circuit board onto a clean surface to steady the device.
  12. Garmin Nuvi 2689LMT Speaker Replacement: 手順 12、 2の画像 1 Garmin Nuvi 2689LMT Speaker Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    購入する
    • Melt and separate the the two metal connections on the circuit using a soldering iron then remove the wires using tweezers.
    • Soldering irons will reach extremely high temperatures and should be used with caution.
  13. Garmin Nuvi 2689LMT Speaker Replacement: 手順 13、 1の画像 1
    • Retrieve your replacement speaker and re-solder the wires back onto the main circuit board.
    • Try to keep the solder on the metal contact points. Avoid heating the plastic circuit board.
終わりに
作成者
5人の作成者と共同で作成されました。
Joseph Lingvay
メンバー登録日: 09/26/16
390 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-5, Eyestone Fall 2016 USF Tampa, Team 16-5, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S16G5
3 メンバー
5のガイドは作成済み
2 件のコメント
Hi what's the make and model of the replacement speaker for the nuvi 2689 model. Where can I find that particular part.
dameongulley - 返信
I have the same question for a NVI mode 2699 deaconwes8@gmail.com
wes nash - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 236
