メインコンテンツにスキップ
Garmin Nuvi 2689 LMT Battery Replacement
必要な工具と部品
  1. Garmin Nuvi 2689 LMT Battery Replacement, Battery: 手順 1、 1の画像 1
    • Remove the stand by pushing down on the tab and pulling the round, plastic piece away from the Garmin unit.
  2. Garmin Nuvi 2689 LMT Battery Replacement: 手順 2、 1の画像 1
    • Remove the four, 4mm hex screws from the four corners of the unit.
    • This will require a T5 Screwdriver.
  3. Garmin Nuvi 2689 LMT Battery Replacement: 手順 3、 1の画像 1
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams, the one on top is artificial.
    • This is the real seam, open it with a plastic opening tool in step 4.
  4. Garmin Nuvi 2689 LMT Battery Replacement: 手順 4、 1の画像 1
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the tool into the unit until you feel a click.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689 LMT Battery Replacement: 手順 5、 1の画像 1
    • Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689 LMT Battery Replacement: 手順 6、 1の画像 1
    • Wedge an angled plastic prying tool under the connector at the part where the wires attach and gently pry up.
    • The battery is connected to the main circuit board via two wires, red and green in color, and is attached with a white connector. It should come free easily.
  7. Garmin Nuvi 2689 LMT Battery Replacement: 手順 7、 1の画像 1
    • The white battery is attached to the casing with an adhesive. It should be easy to pry the battery up with a prying tool.
終わりに
Plug the new battery into the same plug, with the wires going the same direction.
Test the unit by powering it on.
If it powers on stick the new battery in place with any glue or tape.
Snap the casing back together and replace the 4 screws, again with a T5 bit.
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joseph Lingvay
メンバー登録日: 09/26/16
390 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-5, Eyestone Fall 2016 USF Tampa, Team 16-5, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S16G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 31
今までの合計 4,040
