メインコンテンツにスキップ
Garmin Nuvi 2597LMT Speaker Replacement
必要な工具と部品
  1. Garmin Nuvi 2597LMT Speaker Replacement, Speaker: 手順 1、 2の画像 1 Garmin Nuvi 2597LMT Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Garmin Nuvi 2597LMT Speaker Replacement: 手順 2、 3の画像 1 Garmin Nuvi 2597LMT Speaker Replacement: 手順 2、 3の画像 2 Garmin Nuvi 2597LMT Speaker Replacement: 手順 2、 3の画像 3
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along all sides if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
    • Open your device from the top, so that you don't disconnect the ribbon cable.
  3. Garmin Nuvi 2597LMT Speaker Replacement: 手順 3、 2の画像 1 Garmin Nuvi 2597LMT Speaker Replacement: 手順 3、 2の画像 2
    • Use your thin spudger to gently lift the speaker off of the sticky pad and away from the casing.
  4. Garmin Nuvi 2597LMT Speaker Replacement: 手順 4、 2の画像 1 Garmin Nuvi 2597LMT Speaker Replacement: 手順 4、 2の画像 2
    • Use your soldering iron to disconnect the wires from the motherboard. Disconnect the ground wire (the black one) and the positive wire (the blue one).
    • The soldering iron is very hot and do not touch the wires to anything as it may stick to it when it cools.
    • After you have finished this step and the wire ends have cooled, you can safely set the removed speaker aside.
    Toward the beginning, just above the Introduction section, it says "Parts - no parts required." That doesn't make any sense. Isn't the whole point of the procedure to replace the defective speaker? You would have to buy a new replacement speaker. No idea where you would get one except from Garmin, and I bet the cost is unjustifiable.
    Artie Abrams - 返信
終わりに
作成者
2人の作成者と共同で作成されました。
Patrick McNett
メンバー登録日: 10/03/16
887 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-4, Sullivan Fall 2016 USF Tampa, Team 1-4, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G4
4 メンバー
5のガイドは作成済み
4 件のコメント
Great article! Where can I buy replacement speaker?
Zagreb - 返信
At this time, I do not see many options other than purchasing an external speaker like http://www.ebay.com/itm/Garmin-GPS-Exter...
Other options include going to a local repair shop to see if they would sell a generic speaker, as I do not think this is a Garmin specific speaker and that one of a similar size would also work.
I hope you find this guide helpful, have a wonderful day.
Matthew Monnik -
Very good article, any idea where replacement speaker or compatible speaker can be purchased? The original comes from a company that only sells in bulk. Thanks much. John.
mrjgs70 - 返信
One might try going to a local repair shop to see if they would sell a generic speaker, as I do not think this is a Garmin specific speaker and that one of a similar size would also work. Or, an external speaker might work and are relatively cheap on sites like ebay.com. I do not know of any suppliers of this specific model.
Matthew Monnik -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,379
