はじめに
This guide will walk you through the process of replacing a faulty or broken motherboard in your Garmin Nuvi 2597LMT. You may need this guide to replace the motherboard if you know it is broken, the device doesn't run at all, or if you know the motherboard got water damaged. Make sure you are very careful when working with your device; you don't want to break any of the fragile components inside or rip the ribbon cable connecting the two halves.
必要な工具と部品
Turn your device over so the back is revealed and you can see the screws in the four corners.
Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
Use your tweezers to flip back the tab of the ZIF (Zero Insertion Force) Connector, that is used to keep the ribbon cable in place.
3 の人々がこのガイドを完成させました。
3 件のコメント
Thanks Patrick. I'm using your guide for reference when opening my Nuvi 2495 LMT. The MicroSD card slot quit latching so I wanted to see if its gummed up or something else. I didn't know where to start aside from removing the screws on back. Now I know where to pry.
I needed to know what size Torx driver I needed. Thank you! This is very easy to follow. I’m sure I’ll have no problems now replacing my battery.
myfblogin - 返信
