メインコンテンツにスキップ
Garmin Nuvi 2597LMT Microphone Replacement
必要な工具と部品
  1. Garmin Nuvi 2597LMT Microphone Replacement, Microphone: 手順 1、 2の画像 1 Garmin Nuvi 2597LMT Microphone Replacement, Microphone: 手順 1、 2の画像 2
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Garmin Nuvi 2597LMT Microphone Replacement: 手順 2、 3の画像 1 Garmin Nuvi 2597LMT Microphone Replacement: 手順 2、 3の画像 2 Garmin Nuvi 2597LMT Microphone Replacement: 手順 2、 3の画像 3
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along all sides if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
    • Open your device from the top, so that you don't disconnect the ribbon cable.
  3. Garmin Nuvi 2597LMT Microphone Replacement: 手順 3、 3の画像 1 Garmin Nuvi 2597LMT Microphone Replacement: 手順 3、 3の画像 2 Garmin Nuvi 2597LMT Microphone Replacement: 手順 3、 3の画像 3
    • Use your soldering iron to disconnect the wires from the motherboard. Disconnect the ground wire (the black one) and the positive wire (the red one).
    • The soldering iron is very hot and do not touch the wires to anything as it may stick to it when it cools.
  4. Garmin Nuvi 2597LMT Microphone Replacement: 手順 4、 2の画像 1 Garmin Nuvi 2597LMT Microphone Replacement: 手順 4、 2の画像 2
    • Use your hands to grab the wires, and gently pull the microphone up and out of the casing.
    • After this step is complete, you can safely set the removed microphone aside.
終わりに
作成者
2人の作成者と共同で作成されました。
Patrick McNett
メンバー登録日: 10/03/16
887 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-4, Sullivan Fall 2016 USF Tampa, Team 1-4, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G4
4 メンバー
5のガイドは作成済み
2 件のコメント
Where do I buy a new microphone?
Rich Hollabaugh - 返信
Good question! I think that the mic on my Nuvi 465W "ist kaput", but Garmin does not sell any internal replacement components!
Jack McGhee - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 572
