はじめに
This guide will walk you through the process of replacing a faulty or broken LCD screen in your Garmin Nuvi 2597LMT. You may need this guide to replace the LCD if it is cracked, not showing anything at all, not responding to touch, or pixelated. Make sure you are very careful when working with your device; you don't want to break any of the fragile components inside or rip the ribbon cable connecting the two halves.
必要な工具と部品
Use your tweezers to flip back the tab of the ZIF (Zero Insertion Force) Connector, that is used to keep the ribbon cable in place.
Use your hands to pull back the clips that hold the LCD in place.
I got a new LCD from eBay for $15.05 including shipping from China. I followed these directions, and it works fine.
wayneitano - 返信
3 の人々がこのガイドを完成させました。
