メインコンテンツにスキップ
はじめに
This guide will walk you through the process of replacing a faulty or broken battery in your Garmin Nuvi 2597LMT. You may need this guide to replace the battery if you know it is broken, it won't charge, or if you just want to replace the battery. Make sure you are very careful when working with your device; you don't want to break any of the fragile components inside or rip the ribbon cable connecting the two halves.
  1. Turn your device over so the back is revealed and you can see the screws in the four corners. Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along the sides and the top seams if need be. Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable. Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along the sides and the top seams if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
  3. Locate the battery and then use your spudger to gently lift the battery, which is held to the case using a sticky pad, and free it from its position. When you remove the battery, do so slowly so that the wires connecting it to the motherboard aren't torn. The wires will be disconnected in the next step.
    • Locate the battery and then use your spudger to gently lift the battery, which is held to the case using a sticky pad, and free it from its position.
    • When you remove the battery, do so slowly so that the wires connecting it to the motherboard aren't torn. The wires will be disconnected in the next step.
  4. Use your hands or a spudger to gently lift the wires from underneath to disconnect the connector from the motherboard. Once you have disconnected the battery from the motherboard, you can safely set it aside.
    • Use your hands or a spudger to gently lift the wires from underneath to disconnect the connector from the motherboard.
    • Once you have disconnected the battery from the motherboard, you can safely set it aside.
終わりに
5 の人々がこのガイドを完成させました。
Patrick McNett
メンバー登録日: 2016年10月03日
806 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-4, Sullivan Fall 2016 USF Tampa, Team 1-4, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 2,427
