メインコンテンツにスキップ
Garmin Nuvi 2589LMT Display Assembly Replacement
必要な工具と部品
  1. Garmin Nuvi 2589LMT Display Assembly Replacement, Back Panel Assembly: 手順 1、 1の画像 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Display Assembly Replacement: 手順 2、 2の画像 1 Garmin Nuvi 2589LMT Display Assembly Replacement: 手順 2、 2の画像 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Display Assembly Replacement, Display Assembly: 手順 3、 1の画像 1
    • Using the tweezers, gently pull the ribbon wiring near where it connects to the motherboard to disconnect the ribbon wiring and the display screen from the motherboard.
    • Remove the screen from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Adam Ferraro
メンバー登録日: 10/04/16
920 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016人のメンバー
USFT-NANCE-F16S1G2
4 メンバー
8のガイドは作成済み
2 件のコメント
Could you please advise where can I find replacement screen for this device
joyarvind - 返信
I got the ribbon off. There is a plastic piece that flops around that the ribbon was adhered to. Will the replacement ribbon have some type of adhesive on it for installation? Thanks.
Marty Griffin - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 2,404
