この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your device is not turning on you may need to replace a dead or faulty battery. Use this guide to replace the battery in your Garmin NUVI 2589 by completing the following replacement guide.
必要な工具と部品
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
3 の人々がこのガイドを完成させました。
3 件のコメント
Where can I buy this battery
Stan Levin
stan levin - 返信
where can I buy this battery
stan levin - 返信
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
