メインコンテンツにスキップ
Garmin Nuvi 2589LMT Battery Replacement
必要な工具と部品
  1. Garmin Nuvi 2589LMT Battery Replacement, Back Panel Assembly: 手順 1、 1の画像 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Battery Replacement: 手順 2、 2の画像 1 Garmin Nuvi 2589LMT Battery Replacement: 手順 2、 2の画像 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Battery Replacement, Battery: 手順 3、 1の画像 1
    • Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
  4. Garmin Nuvi 2589LMT Battery Replacement: 手順 4、 1の画像 1
    • The battery is held in place by adhesive tape on the underside of the battery.
    • Use the opening tools to gently pry underneath the battery and lift upwards to remove the battery.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Adam Ferraro
メンバー登録日: 10/04/16
920 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016人のメンバー
USFT-NANCE-F16S1G2
4 メンバー
8のガイドは作成済み
3 件のコメント
Where can I buy this battery
Stan Levin
stan levin - 返信
where can I buy this battery
stan levin - 返信
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
Hans-Joachim Böhnke - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 4,944
