メインコンテンツにスキップ
Garmin Nuvi 255W Speaker Replacement
必要な工具と部品
  1. Garmin Nuvi 255W Speaker Replacement, Power Button: 手順 1、 1の画像 1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Speaker Replacement: 手順 2、 1の画像 1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Speaker Replacement: 手順 3、 2の画像 1 Garmin Nuvi 255W Speaker Replacement: 手順 3、 2の画像 2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Speaker Replacement: 手順 4、 2の画像 1 Garmin Nuvi 255W Speaker Replacement: 手順 4、 2の画像 2
    • Remove the power button.
  5. Garmin Nuvi 255W Speaker Replacement, Battery: 手順 5、 1の画像 1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Speaker Replacement: 手順 6、 2の画像 1 Garmin Nuvi 255W Speaker Replacement: 手順 6、 2の画像 2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Speaker Replacement: 手順 7、 2の画像 1 Garmin Nuvi 255W Speaker Replacement: 手順 7、 2の画像 2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
  8. Garmin Nuvi 255W Speaker Replacement, Speaker: 手順 8、 1の画像 1
    • Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
  9. Garmin Nuvi 255W Speaker Replacement: 手順 9、 2の画像 1 Garmin Nuvi 255W Speaker Replacement: 手順 9、 2の画像 2
    • Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
終わりに
作成者
3人の作成者と共同で作成されました。
Timothy
メンバー登録日: 01/26/12
73 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 9-3, Regan Winter 2012 Cal Poly, Team 9-3, Regan Winter 2012人のメンバー
CPSU-REGAN-W12S9G3
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 3,958
