はじめに
The tools needed are T5 Torx Screwdriver and a plastic opening tool in order to get into the device. After that - your hands will be enough.
必要な工具と部品
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
With the screen facing down, firmly grip the sides of the screen frame and pop the screen out.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
