メインコンテンツにスキップ
はじめに
The needed tools are a T5 Torx Screwdriver and a plastic opening tool. In order to get to the inside of the device the nameplate and the back of the device will be taken off.
パーツ
パーツは指定されていません。
  1. Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. There is a visible separation between the front and the back of the device.
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Carefully pull apart the device by opening it up on the opposite side of the nameplate. Carefully pull apart the device by opening it up on the opposite side of the nameplate.
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
終わりに
ある他の人がこのガイドを完成しました。
Danis Terzi
メンバー登録日: 2016年03月31日
349 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 1-3, Giguere Spring 2016 Eastern Washington University, Team 1-3, Giguere Spring 2016人のメンバー
EWU-GIGUERE-S16S1G3
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 11
今までの合計 825
