メインコンテンツにスキップ
Garmin Nuvi 200w Screen Replacement
必要な工具と部品
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: 手順 1、 3の画像 1 Garmin Nuvi 200w Screen Replacement, Rear Cover: 手順 1、 3の画像 2 Garmin Nuvi 200w Screen Replacement, Rear Cover: 手順 1、 3の画像 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: 手順 2、 1の画像 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: 手順 3、 3の画像 1 Garmin Nuvi 200w Screen Replacement: 手順 3、 3の画像 2 Garmin Nuvi 200w Screen Replacement: 手順 3、 3の画像 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: 手順 4、 2の画像 1 Garmin Nuvi 200w Screen Replacement: 手順 4、 2の画像 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: 手順 5、 3の画像 1 Garmin Nuvi 200w Screen Replacement, Display Assembly: 手順 5、 3の画像 2 Garmin Nuvi 200w Screen Replacement, Display Assembly: 手順 5、 3の画像 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: 手順 6、 3の画像 1 Garmin Nuvi 200w Screen Replacement, Screen: 手順 6、 3の画像 2 Garmin Nuvi 200w Screen Replacement, Screen: 手順 6、 3の画像 3
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
終わりに
作成者
3人の作成者と共同で作成されました。
Matthew Eires
メンバー登録日: 03/08/17
319 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 UMass Dartmouth, Team S5-G4, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 342
