Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
Once you have a little gap, work it around the whole device with the tool to get separation.
There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
Slide the orange ribbon cable away from the ZIF connector.
Using a screw driver, unscrew the four 2mm screws holding the motherboard in place.
Gently lift the motherboard away from the rear cover. Take care to not damage the wires or ports that link the motherboard to other components.
Using the black spudger, apply pressure to nudge the plug out of its port.
Repeat this process for both ports.
Using your opening tools, separate the battery from the top side. Very slowly push your tool down into the crevice.
Be careful because the battery is glued to the rear cover, so it does take some force to separate.
Once you have a gap big enough, pull the battery off the cover.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
