メインコンテンツにスキップ
Garmin Nuvi 200w Battery Replacement
必要な工具と部品
  1. Garmin Nuvi 200w Battery Replacement, Rear Cover: 手順 1、 3の画像 1 Garmin Nuvi 200w Battery Replacement, Rear Cover: 手順 1、 3の画像 2 Garmin Nuvi 200w Battery Replacement, Rear Cover: 手順 1、 3の画像 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Battery Replacement: 手順 2、 1の画像 1
    • Remove the two 4mm T5 Torx screws.
    What size screwdriver do I need?
    Roman Justice - 返信
  3. Garmin Nuvi 200w Battery Replacement: 手順 3、 3の画像 1 Garmin Nuvi 200w Battery Replacement: 手順 3、 3の画像 2 Garmin Nuvi 200w Battery Replacement: 手順 3、 3の画像 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
    No connecting cable in the picture. Perhaps include a photo or direct the reader to one in a future step.
    Roman Justice - 返信
  4. Garmin Nuvi 200w Battery Replacement: 手順 4、 2の画像 1 Garmin Nuvi 200w Battery Replacement: 手順 4、 2の画像 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Battery Replacement, Display Assembly: 手順 5、 3の画像 1 Garmin Nuvi 200w Battery Replacement, Display Assembly: 手順 5、 3の画像 2 Garmin Nuvi 200w Battery Replacement, Display Assembly: 手順 5、 3の画像 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
    My 200W had a different connector arrangement. I couldn’t disconnect the display cable which connected into the middle of the motherboard not the edge as shown, nor the other two cables either side, but if I was careful I could get enough clearance to undo the screws holding the motherboard (one of which was under a metal screen which was stuck down but could be peeled back).
    James Warren - 返信
  6. Garmin Nuvi 200w Battery Replacement, Motherboard: 手順 6、 2の画像 1 Garmin Nuvi 200w Battery Replacement, Motherboard: 手順 6、 2の画像 2
    • Using a screw driver, unscrew the four 2mm screws holding the motherboard in place.
    • Gently lift the motherboard away from the rear cover. Take care to not damage the wires or ports that link the motherboard to other components.
  7. Garmin Nuvi 200w Battery Replacement: 手順 7、 3の画像 1 Garmin Nuvi 200w Battery Replacement: 手順 7、 3の画像 2 Garmin Nuvi 200w Battery Replacement: 手順 7、 3の画像 3
    • Using the black spudger, apply pressure to nudge the plug out of its port.
    • Repeat this process for both ports.
  8. Garmin Nuvi 200w Battery Replacement, Battery: 手順 8、 3の画像 1 Garmin Nuvi 200w Battery Replacement, Battery: 手順 8、 3の画像 2 Garmin Nuvi 200w Battery Replacement, Battery: 手順 8、 3の画像 3
    • Using your opening tools, separate the battery from the top side. Very slowly push your tool down into the crevice.
    • Be careful because the battery is glued to the rear cover, so it does take some force to separate.
    • Once you have a gap big enough, pull the battery off the cover.
終わりに
作成者
3人の作成者と共同で作成されました。
Matthew Eires
メンバー登録日: 03/08/17
319 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 UMass Dartmouth, Team S5-G4, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 45
過去 30 日: 171
今までの合計 833
