メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The back cover to the Garmin Nuvi 200W is exposed more than other internal elements of the device. Due to this vulnerable position, the cover may become scratched, damaged, or broken under stress. Replacing the rear cover can make the Nuvi 200W look new again, at much less cost!
It is important to note, however, that the case and it's internals require very specific screws, that are small and easy to lose. It is recommended that a magnet or tap is used to secure screws after removal. It is also important to gently remove the back cover, as it will be attached to other interior elements. This connection is sensitive and should be treated as such until the guide shows proper disconnection of this particular cable.
Only basic tools are required, such as screw drivers, and opening tools.
パーツ
パーツは指定されていません。
  1. Peel off the sticker in order to find the two Torx T5 screws. Peel off the sticker in order to find the two Torx T5 screws. Peel off the sticker in order to find the two Torx T5 screws.
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Remove the two 4mm T5 Torx screws.
    • Remove the two 4mm T5 Torx screws.
  3. Carefully, using your plastic opening tools find the crease which separates the front and rear covers. Once you have a little gap, work it around the whole device with the tool to get separation. There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable. After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
終わりに
Matthew Eires
メンバー登録日: 2017年03月08日
319 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 UMass Dartmouth, Team S5-G4, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S5G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 126
