メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Replacing the speaker in a Garmin Nuvi 200.
  1. Peel off the sticker from the bottom of the device to reveal two screws. Peel off the sticker from the bottom of the device to reveal two screws.
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Remove two T5 Torx screws.
    • Remove two T5 Torx screws.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Insert a plastic opening tool in the gap between the front and rear casing. Carefully work the tool around the gap, separating the two halves of the case.
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  5. Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    there is no use showing how to replace a speaker in nuvi if we cant find any
    seems like a god dam mistery
    Jean Michel Tche - 返信
  6. Pull the cable out to detach the speaker from the logic board.
    • Pull the cable out to detach the speaker from the logic board.
  7. Wedge the iPod opener into the space between the speaker and the case. Apply pressure to pry the speaker away from the case. Apply pressure to pry the speaker away from the case.
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
終わりに
3 の人々がこのガイドを完成させました。
Anjelica
メンバー登録日: 2010年04月11日
504 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G90
4 メンバー
9のガイドは作成済み
2 件のコメント
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - 返信
Where can you buy replacement speakers for the Garmin units?
Brat Fry - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 6,641
