メインコンテンツにスキップ
Garmin Nüvi 52LM Battery Replacement
必要な工具と部品
  1. Garmin Nüvi 52LM Battery Replacement, Garmin Nüvi 52LM Disassembly: 手順 1、 2の画像 1 Garmin Nüvi 52LM Battery Replacement, Garmin Nüvi 52LM Disassembly: 手順 1、 2の画像 2
    • Place the device face-down, with the screen facing the surface. There are 8.7mm screws located in each of the back 4 corners of the device. Using a T5 Torx screw bit, unscrew all four screws and leave them aside.
  2. Garmin Nüvi 52LM Battery Replacement: 手順 2、 2の画像 1 Garmin Nüvi 52LM Battery Replacement: 手順 2、 2の画像 2
    • Place a plastic opening tool in the seam between the back and front plates of the device. Using constant pressure, slowly and continuously slide the tool along the seam. The tool should disable each of the hooks holding the two plates together. If unsuccessful, apply slightly more pressure and try again.
    • Once all hooks are disabled, slowly separate the two plates, being careful not to damage the ribbon wire still connecting the two.
  3. Garmin Nüvi 52LM Battery Replacement, Battery: 手順 3、 2の画像 1 Garmin Nüvi 52LM Battery Replacement, Battery: 手順 3、 2の画像 2
    • Using the T5 Torx screwdriver, unscrew the two 5.6mm screws at the top right and bottom right corners of the motherboard.
  4. Garmin Nüvi 52LM Battery Replacement: 手順 4、 2の画像 1 Garmin Nüvi 52LM Battery Replacement: 手順 4、 2の画像 2
    • Gently unplug the wire connecting the battery to the small socket on the back of the motherboard.
  5. Garmin Nüvi 52LM Battery Replacement: 手順 5、 2の画像 1 Garmin Nüvi 52LM Battery Replacement: 手順 5、 2の画像 2
    • Using a plastic opening tool, pry the battery from the back cover of the device. There may be an adhesive sticker keeping it in place, so you may need to apply some force.
    • The battery should now be completely detached from the other parts.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Camron Dennler
メンバー登録日: 01/24/17
146 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-1, Banghart Winter 2017 Cal Poly, Team 10-1, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S10G1
4 メンバー
5のガイドは作成済み
コメント 1 件
I was told the small connector at the back of my device is the problem. I am thinking it may be the battery. I don’t really want to throw my gps away if I can fix it! Thanks!
gsolomon77 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 2,269
