メインコンテンツにスキップ
Garmin Nüvi 205W LCD Display Replacement
必要な工具と部品
  1. Garmin Nüvi 205W LCD Display Replacement, LCD Display: 手順 1、 3の画像 1 Garmin Nüvi 205W LCD Display Replacement, LCD Display: 手順 1、 3の画像 2 Garmin Nüvi 205W LCD Display Replacement, LCD Display: 手順 1、 3の画像 3
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
  2. Garmin Nüvi 205W LCD Display Replacement: 手順 2、 3の画像 1 Garmin Nüvi 205W LCD Display Replacement: 手順 2、 3の画像 2 Garmin Nüvi 205W LCD Display Replacement: 手順 2、 3の画像 3
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
  3. Garmin Nüvi 205W LCD Display Replacement: 手順 3、 3の画像 1 Garmin Nüvi 205W LCD Display Replacement: 手順 3、 3の画像 2 Garmin Nüvi 205W LCD Display Replacement: 手順 3、 3の画像 3
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
  4. Garmin Nüvi 205W LCD Display Replacement: 手順 4、 3の画像 1 Garmin Nüvi 205W LCD Display Replacement: 手順 4、 3の画像 2 Garmin Nüvi 205W LCD Display Replacement: 手順 4、 3の画像 3
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
  5. Garmin Nüvi 205W LCD Display Replacement: 手順 5、 3の画像 1 Garmin Nüvi 205W LCD Display Replacement: 手順 5、 3の画像 2 Garmin Nüvi 205W LCD Display Replacement: 手順 5、 3の画像 3
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
  6. Garmin Nüvi 205W LCD Display Replacement: 手順 6、 3の画像 1 Garmin Nüvi 205W LCD Display Replacement: 手順 6、 3の画像 2 Garmin Nüvi 205W LCD Display Replacement: 手順 6、 3の画像 3
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
oldturkey03
メンバー登録日: 09/29/10
784,117 ポイント
119のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
555のガイドは作成済み
2 件のコメント
After reinstalling LCD screen how do I reconnect the ribbon cable? Any tips would be GREATLY appreciated :) Thank You
John - 返信
Thank you! Saved me a new GPS!
worthless0000 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 14
今までの合計 3,354
