はじめに
This Garmin had a cracked front glass/digitizer. Due to cost effectiveness I replaced the complete front panel. Replacement cost $20.
  1. The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • The cracked screen is clearly visible. LCD is still functioning, but obviously no touch function.
    • Remove the holder as well as the power cord from the back of the GPS unit.
    • The Nüvi uses two screws that are hidden underneath the label on the bottom.
  2. Remove the label, then remove the two Torx T5 screws
    • Remove the label, then remove the two Torx T5 screws
    • Use a plastic opening tool to start splitting the front and back case.
    • Work your way around the separation line, gently applying continous pressure to the back case.
    • Once the front and back case are split, do not yet totally remove it. The LCD is still attached via a ribbon cable.
    • The ribbon cable and connector are covered with a strip of Kapton tape
    • Remove the tape. Use the plastic opening tool, or any other appropriate tool (i.e. guitar pick, fingernails etc), to remove the tape.
    • Once the tape is removed, flip the white clasp open, by moving it away from the cable end, disconnect the LCD.
    • Remove the On/Off switch
    • Remove the complete front assembly.
    • The LCD assembly is held in the front bezel by seven plastic tabs.
    • Move those tabs slightly back while applying pressure from the opposite side (front of the LCD)
    • Continue to push the tabs on the bezel away from the LCD assembly, pushing the LCD away from the bezel
    • Ensure that the LCD assembly clears all the tabs.
    • Remove the LCD from the front bezel
    • Totally separate the assembly from the bezel. Now it is time to replace it with a new assembly.
まとめ
2 の人々がこのガイドを完成させました。
oldturkey03
メンバー登録日: 2010年09月29日
554,980 ポイント
101のガイドは作成済み
チーム
OTS OTS人のメンバー
Business
1 メンバー
123のガイドは作成済み
After reinstalling LCD screen how do I reconnect the ribbon cable? Any tips would be GREATLY appreciated :) Thank You
John - 返信
Thank you! Saved me a new GPS!
worthless0000 - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 2,830
