メインコンテンツにスキップ
Garmin GPS V Logic Board Replacement
必要な工具と部品
  1. Garmin GPS V Logic Board Replacement, Logic Board: 手順 1、 3の画像 1 Garmin GPS V Logic Board Replacement, Logic Board: 手順 1、 3の画像 2 Garmin GPS V Logic Board Replacement, Logic Board: 手順 1、 3の画像 3
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
  2. Garmin GPS V Logic Board Replacement: 手順 2、 2の画像 1 Garmin GPS V Logic Board Replacement: 手順 2、 2の画像 2
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
  3. Garmin GPS V Logic Board Replacement: 手順 3、 2の画像 1 Garmin GPS V Logic Board Replacement: 手順 3、 2の画像 2
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
  4. Garmin GPS V Logic Board Replacement: 手順 4、 2の画像 1 Garmin GPS V Logic Board Replacement: 手順 4、 2の画像 2
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
  5. Garmin GPS V Logic Board Replacement: 手順 5、 3の画像 1 Garmin GPS V Logic Board Replacement: 手順 5、 3の画像 2 Garmin GPS V Logic Board Replacement: 手順 5、 3の画像 3
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
  6. Garmin GPS V Logic Board Replacement: 手順 6、 2の画像 1 Garmin GPS V Logic Board Replacement: 手順 6、 2の画像 2
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
  7. Garmin GPS V Logic Board Replacement: 手順 7、 1の画像 1
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Connor
メンバー登録日: 01/23/12
194 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 3-25, Amido Winter 2012 Cal Poly, Team 3-25, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G25
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 5,574
