メインコンテンツにスキップ
Garmin Forerunner 10 Battery Replacement
必要な工具と部品
  1. Garmin Forerunner 10 Battery Replacement, Battery: 手順 1、 2の画像 1 Garmin Forerunner 10 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Use the Torx 5 Screwdriver to remove all four 1.1 mm screws on the back of the watch.
  2. Garmin Forerunner 10 Battery Replacement: 手順 2、 1の画像 1
    • Place the watch upside down and lift the back panel from the watch.
    • Remove the battery housing from the watch.
    • Place the housing face up to ensure that the two springs do not fall out.
    • Some have noted that certain features of the watch do not work if the springs are mixed up. Be sure they stay in place.
  3. Garmin Forerunner 10 Battery Replacement: 手順 3、 1の画像 1
    • Secure the two springs with two small pieces of scotch tape to ensure the springs do not fall out.
  4. Garmin Forerunner 10 Battery Replacement: 手順 4、 2の画像 1 Garmin Forerunner 10 Battery Replacement: 手順 4、 2の画像 2
    • Remove the 8 metal latches from the black battery housing.
    • Gently bend the 8 metal latches slightly away from the black battery housing.
  5. Garmin Forerunner 10 Battery Replacement: 手順 5、 1の画像 1
    • DO NOT directly touch the circuit board on the motherboard of the watch. This will render your watch inoperable.
    • Grab the motherboard from its sides and set it aside in a safe place.
  6. Garmin Forerunner 10 Battery Replacement: 手順 6、 2の画像 1 Garmin Forerunner 10 Battery Replacement: 手順 6、 2の画像 2
    • Separate the clear tape attached to the battery.
    • Be gentle! You will be reusing this tape for the new battery.
  7. Garmin Forerunner 10 Battery Replacement: 手順 7、 2の画像 1 Garmin Forerunner 10 Battery Replacement: 手順 7、 2の画像 2
    • Prepare your new battery.
    • Secure the battery under the tape.
    • The + sign should face away from the tape.
終わりに
To reassemble the watch, follow these instructions in reverse order. Charge your watch when finished. Check to make sure all features are working.
14 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alana Joldersma
メンバー登録日: 04/28/17
465 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S3-G3, Coad Spring 2017 UC Davis, Team S3-G3, Coad Spring 2017人のメンバー
UCD-COAD-S17S3G3
3 メンバー
2のガイドは作成済み
10 件のコメント
This was probably beyond my skill level, but I tried this and it seemed straightforward, but after re-assembly, when I hooked it up to the charge cable, the watch doesn't seem to be charging and won't turn on.
ericcox1 - 返信
Did you get it work?
Ruslan -
great guide! thanks so much for sharing!
Lindso - 返信
Thanks you for sharing. Easy enough to follow. A bit fiddly but took my time and made sure I had a small box to keep the bits in while I waited for the new battery to arrive. One of the springs did pop out (Step 2) but I didn’t lose it!! Reassembled and the watch turns on so all looking good! I think my old battery leaked so I am hoping no internal damage was done and the watch can recharge the new battery.
Jon Titchmarsh - 返信
Also works on the Garmin Forerunner 15
Extra hints:
Step 2 - The red seal can come out with the back - carefully place it back into its slot in the body of the watch before reassembly. It only goes in one way. Not sure about turning it over to be ‘face up’ as the springs will fall out. Move onto step 3 and tape them, etc.
Step 3 - you can tape the springs, but when the motherboard is removed, they can fall out the back. Consider carefully removing them first and setting aside in the matching pattern for easy replacement
Steps 4-6 - all good, but don’t bend those metal clips too much…
Step 7 - consider taking the tape off the front of the battery (+ side) as well and moving to the new one
Step 8 - reassembly of motherboard - carefully compress each corner and feel as each clip ‘clicks’ back into place
Step 9 - place back in housing, making sure it sits level
Step 10 - replace back of watch - a few careful jiggles may be required as there are 6 different springs to get touching at the right places.
John Magnussen - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 34
過去 30 日: 126
今までの合計 30,990
