メインコンテンツにスキップ
Garmin Fenix 5 Cleaning
必要な工具と部品
  1. Garmin Fenix 5 Cleaning, Front screws: 手順 1、 2の画像 1 Garmin Fenix 5 Cleaning, Front screws: 手順 1、 2の画像 2
    • Remove the strap
    • Power-off the device
    • Remove the screws on the front using the Torx T4 screwdriver
  2. Garmin Fenix 5 Cleaning, Rear screws: 手順 2、 1の画像 1
    • Remove the screws on the rear using the Torx T6 (or TR6) screwdriver
  3. Garmin Fenix 5 Cleaning, The small arc: 手順 3、 2の画像 1 Garmin Fenix 5 Cleaning, The small arc: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Remove the small grey arc on the top of the device with the tweezers
  4. Garmin Fenix 5 Cleaning, Remove the screen: 手順 4、 1の画像 1
    • With the tweezers, remove the pin connector linked to the screen
    • Remove the screen
  5. Garmin Fenix 5 Cleaning, Free the motherboard: 手順 5、 2の画像 1 Garmin Fenix 5 Cleaning, Free the motherboard: 手順 5、 2の画像 2
    • Remove the 2 screws on the motherboard using the PH #000 screwdriver
  6. Garmin Fenix 5 Cleaning, The sensor: 手順 6、 2の画像 1 Garmin Fenix 5 Cleaning, The sensor: 手順 6、 2の画像 2
    • Remove the 2 screws holding the sensor between the buttons on the right side of the case
    • With the tweezers, remove the sensor and detach the case from the motherboard
  7. Garmin Fenix 5 Cleaning, Gasket and buttons: 手順 7、 3の画像 1 Garmin Fenix 5 Cleaning, Gasket and buttons: 手順 7、 3の画像 2 Garmin Fenix 5 Cleaning, Gasket and buttons: 手順 7、 3の画像 3
    • Remove the seal around the circumference of the watch casing, as you will be handling the casing a lot and you don’t want to risk tearing the gasket.
    • Using the tweezers, remove the circlips around every button very carefully.
    • When the circlips are removed, you can pull the buttons off. Do this step carefully because you will also find a return spring inside every button hole
  8. Garmin Fenix 5 Cleaning, Clean case and buttons: 手順 8、 1の画像 1
    • Clean the case, including the hole of the buttons
    • Clean the buttons and the springs
    • (OPTIONAL) You can lubrificate the buttons before re-inserting them in the case
    • Reassemble the watch
終わりに
10 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Garmin Boy
メンバー登録日: 04/28/21
412 ポイント
1ガイドが承認済み
15件のガイドコメント
Thanks for that info. In looking at the pictures, I can’t tell which piece is the battery. Do you think it can be easily replaced? Or is it soldered in? Thanks.
Patrick Chang - 返信
Hi,
the battery is visible in the step 5 and step 6.
It is linked to the mainborad with a connector, It’s not soldered.
It’s glued to the back cover but, in my opinion, it can be easy replaced.
The battery type is "361-00097-00"
The nominal specifications are 255mAh, 0.97Wh and 3.8V
On ebay you can find a new battery: https://www.ebay.it/itm/283519139846?has...
I hope this can help
Garmin Boy -
Maybe do You know where to purchase a gaskets?
Edgaras Tamošauskas - 返信
Unfortunately, I don’t know where you can find it.
I’ve searched on my favourite websites with no luck.
Garmin Boy -
Question: do I need to disasassemble the screen to change only the battery? Can I just access to it by the rear cover?
Thanks for the info!
Cristóbal Sabroe Yde - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 76
過去 30 日: 354
今までの合計 19,660
