メインコンテンツにスキップ
Garmin Fenix 3 Battery Replacement
必要な工具と部品
  1. Garmin Fenix 3 Battery Replacement, Display Assembly: 手順 1、 2の画像 1 Garmin Fenix 3 Battery Replacement, Display Assembly: 手順 1、 2の画像 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Battery Replacement: 手順 2、 1の画像 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Battery Replacement: 手順 3、 1の画像 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Battery Replacement: 手順 4、 1の画像 1
    • Set the watch face aside.
  5. Garmin Fenix 3 Battery Replacement, GPS Antenna: 手順 5、 1の画像 1
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 Battery Replacement: 手順 6、 1の画像 1
    • Carefully remove the antenna, and set it aside.
  7. Garmin Fenix 3 Battery Replacement, Battery: 手順 7、 3の画像 1 Garmin Fenix 3 Battery Replacement, Battery: 手順 7、 3の画像 2 Garmin Fenix 3 Battery Replacement, Battery: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Use a T5 screwdriver to remove the two silver 1.4 mm screws from the motherboard.
    • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
  8. Garmin Fenix 3 Battery Replacement: 手順 8、 2の画像 1 Garmin Fenix 3 Battery Replacement: 手順 8、 2の画像 2
    • Lift the watch and turn it over one hand. The motherboard should fall out easily.
    • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
  9. Garmin Fenix 3 Battery Replacement: 手順 9、 1の画像 1
    • Using the spludger, separate the battery from the motherboard, which are both held together with a mild adhesive. Note that the battery connector lifts upward away from the circuit board by simply lifting the wires up should pop the connector.
    • When re-seating the new battery connector make sure the connector is seated home fully or it will not work and the the watch will show "100%" when on the charger but will not start.
終わりに
21 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Adam Estabrook
メンバー登録日: 09/07/18
1,131 ポイント
5のガイドは作成済み
チーム
Appalachian State University, Team S1-G3, Menagarishvili Fall 2018 Appalachian State University, Team S1-G3, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S1G3
3 メンバー
11のガイドは作成済み
36件のガイドコメント
Ruined my watch… The battery connection socket ripped off with the battery connector…
I have taken apart phones and laptops in the past without issue, so I am not inexperienced by any means. I was as careful as possible.
John Smith - 返信
Sounds like it may have had a factory defect. I did the same fix and it worked fine, just like any other computer or phone.
Hamilton Cooper -
Excellent guide - thanks! My Fenix3 wasn't charging any more so following your guide I replaced the ‘dead’ battery with a new one with ease. However, when reassembled, the new battery worked but would not charge. I took it apart again, and found slight corrosion or gunk on the motherboard terminals where they contact the inner side of the charging pins. After a good clean with meths and a cotton bud I popped the original battery back in, reassembled it, and hey presto! it started charging! Very happy!
Nick Coldham - 返信
I appreciate the guide as my Fenix 3 after 6 years of owning it could barely make it 24 hours without charging it.
The only thing I’d add to the guide is that you can reuse the adhesive from the existing battery as it’s only double-sided tape. Other than, it went flawless!
Roy J. Villarreal III - 返信
Thanks for this. Just did it successfully. A quick note, when you are separating the battery from the motherboard, it pulls up/perpendicular to the device and not parallel to it as I had initially thought. Luckily I did not break the battery connector to the motherboard. When I put it back in I needed to push it towards the motherboard to properly seat it. Look closely to make sure no part of the connector is sticking up, even a hair or it will not work.
Michael Reid - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 138
過去 30 日: 362
今までの合計 29,068
