メインコンテンツにスキップ
Garmin Fenix 2 Housing Replacement
必要な工具と部品
  1. Garmin Fenix 2 Housing Replacement, Watch Straps: 手順 1、 1の画像 1
    • Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
  2. Garmin Fenix 2 Housing Replacement: 手順 2、 1の画像 1
    • Use a Torx T9 screwdriver to remove the four .8mm screws. Once the screws are removed the watch straps should fall out of the housing.
  3. Garmin Fenix 2 Housing Replacement, Battery: 手順 3、 3の画像 1 Garmin Fenix 2 Housing Replacement, Battery: 手順 3、 3の画像 2 Garmin Fenix 2 Housing Replacement, Battery: 手順 3、 3の画像 3
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  4. Garmin Fenix 2 Housing Replacement: 手順 4、 2の画像 1 Garmin Fenix 2 Housing Replacement: 手順 4、 2の画像 2
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  5. Garmin Fenix 2 Housing Replacement: 手順 5、 2の画像 1 Garmin Fenix 2 Housing Replacement: 手順 5、 2の画像 2
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
  6. Garmin Fenix 2 Housing Replacement, Motherboard: 手順 6、 1の画像 1
    • Use a spudger to pry open the power ribbon from the main board.
  7. Garmin Fenix 2 Housing Replacement: 手順 7、 1の画像 1
    • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
  8. Garmin Fenix 2 Housing Replacement: 手順 8、 1の画像 1
    • Use the spudger to pry the motherboard out of the housing.
  9. Garmin Fenix 2 Housing Replacement: 手順 9、 1の画像 1
    • Once removed simply separate the digitizer from the main board.
  10. Garmin Fenix 2 Housing Replacement: 手順 10、 2の画像 1 Garmin Fenix 2 Housing Replacement: 手順 10、 2の画像 2
    • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
  11. Garmin Fenix 2 Housing Replacement, Display: 手順 11、 1の画像 1
    • The display is also ready to be replaced.
  12. Garmin Fenix 2 Housing Replacement, Housing: 手順 12、 2の画像 1 Garmin Fenix 2 Housing Replacement, Housing: 手順 12、 2の画像 2
    • Use a spudger tool to pry the soundboard out of its housing.
  13. Garmin Fenix 2 Housing Replacement: 手順 13、 1の画像 1
    • Remove the gasket seal from the housing.
  14. Garmin Fenix 2 Housing Replacement: 手順 14、 1の画像 1
    • Once all your components are removed the housing with buttons is ready to be repaired/ replaced.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Brandon Barger
メンバー登録日: 02/13/16
1,219 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 54-4, Wilson Spring 2016 IUPUI, Team 54-4, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S54G4
3 メンバー
6のガイドは作成済み
2 件のコメント
Hi there!
Thanks for the tutorial!
When i reassemble the watch, do i have to put some glue to seal the tiny holes out of the soundboard, or those rubber rings does the job?
I’m just afraid of screwing the waterproof feature of the watch…
Thanks!!
Antenor Heleodoro dos Santos - 返信
do you know where i can find atmospheric pressure and temperature sensors?
marco turati - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 19
今までの合計 4,331
