メインコンテンツにスキップ
Garmin Edge 830 Motherboard Replacement
必要な工具と部品
  1. Garmin Edge 830 Motherboard Replacement, Touch Display: 手順 1、 1の画像 1
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
  2. Garmin Edge 830 Motherboard Replacement: 手順 2、 1の画像 1
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
  3. Garmin Edge 830 Motherboard Replacement: 手順 3、 1の画像 1
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Motherboard Replacement, Motherboard: 手順 4、 1の画像 1
    この手順で使用する道具:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Motherboard Replacement: 手順 5、 1の画像 1
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Motherboard Replacement: 手順 6、 1の画像 1
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Motherboard Replacement: 手順 7、 2の画像 1 Garmin Edge 830 Motherboard Replacement: 手順 7、 2の画像 2
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
終わりに
作成者
6人の作成者と共同で作成されました。
Alden Gibbs
メンバー登録日: 03/21/22
265 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 3-2, Bedsole Spring 2022 University of Alabama, Team 3-2, Bedsole Spring 2022人のメンバー
UA-BEDSOLE-S22S3G2
4 メンバー
13のガイドは作成済み
1件のガイドコメント
Hi, i have an issue with Garmin Edsge 830; the problem is that the device cant connect to the phone and the official statemenet from Garmin was that the bluetooth sensor is not working. Is there a way to reapir it? i guess it is soldered on the motherboard, meaning i should change the whole motherboard?
Thanks for the answer
Jan Žužek - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 38
今までの合計 626
