メインコンテンツにスキップ
Garmin Dezl 770LMT Motherboard Replacement
必要な工具と部品
  1. Garmin Dezl 770LMT Motherboard Replacement, Back Panel Removal: 手順 1、 2の画像 1 Garmin Dezl 770LMT Motherboard Replacement, Back Panel Removal: 手順 1、 2の画像 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Motherboard Replacement: 手順 2、 1の画像 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Motherboard Replacement: 手順 3、 1の画像 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Motherboard Replacement, Motherboard: 手順 4、 2の画像 1 Garmin Dezl 770LMT Motherboard Replacement, Motherboard: 手順 4、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
  5. Garmin Dezl 770LMT Motherboard Replacement: 手順 5、 2の画像 1 Garmin Dezl 770LMT Motherboard Replacement: 手順 5、 2の画像 2
    • Using a T5 Torx screwdriver remove the eight screws attaching the motherboard to the case
  6. Garmin Dezl 770LMT Motherboard Replacement: 手順 6、 2の画像 1 Garmin Dezl 770LMT Motherboard Replacement: 手順 6、 2の画像 2
    • Carefully remove the cord connecting the battery to the motherboard, by gently lifting it straight up from the board.
    • Do not pull the cord out towards the battery. The solder joints holding the port onto the mother board may break.
    • If you want to remove the antenna and speaker you will need to desolder them from the mother board. This is not necessary to remove the mother board.
終わりに
作成者
3人の作成者と共同で作成されました。
Francisco Rosado
メンバー登録日: 10/05/16
370 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016人のメンバー
USFT-LACY-F16S1G3
4 メンバー
5のガイドは作成済み
コメント 1 件
Onde posso comprar a Motherbord?
Carlix - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 7
過去 30 日: 20
今までの合計 1,117
