メインコンテンツにスキップ
  1. Be sure to turn off the Dash Cam by pressing the power button. Be sure to turn off the Dash Cam by pressing the power button.
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Rotate the Dash Cam to where the socket faces you. Remove the 9 mm screw using the Torx T6 screwdriver.
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Remove the Dash Cam socket piece. Remove the Dash Cam socket piece.
    • Remove the Dash Cam socket piece.
  4. Rotate the Dash Cam to where the product information faces you. Remove the two 5 mm screws using the Torx T5 screwdriver.
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Remove top case from the bottom case. The compact nature of the casing requires use of the metal spudger for needed leverage. The compact nature of the casing requires use of the metal spudger for needed leverage.
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Remove the two 5mm screws using the Torx T5 screwdriver By removing the screws, the metal battery frame will now become free from the rest of the device. By removing the screws, the metal battery frame will now become free from the rest of the device.
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Use the Phillips screwdriver to remove the four 5mm screws. Use the Phillips screwdriver to remove the four 5mm screws. Use the Phillips screwdriver to remove the four 5mm screws.
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Use the metal spudger to remove metal plate from device. This will reveal the screen. Use the metal spudger to remove metal plate from device. This will reveal the screen.
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Use the metal spudger to remove screen from device. Use the metal spudger to remove screen from device. Use the metal spudger to remove screen from device.
    • Use the metal spudger to remove screen from device.
  10. The screen is now detached.
    • The screen is now detached.
終わりに
ある他の人がこのガイドを完成しました。
Jesse Hillman
メンバー登録日: 2016年10月04日
736 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 322
