メインコンテンツにスキップ
Gamma Scout Geiger Counter Battery Replacement
必要な工具と部品
  1. Gamma Scout Geiger Counter Battery Replacement, Preparation: 手順 1、 2の画像 1 Gamma Scout Geiger Counter Battery Replacement, Preparation: 手順 1、 2の画像 2
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    • Prepare your Gamma Scout geiger counter for the battery replacement.
    • If your geiger counter is in a holster, remove the holster from the geiger counter.
    • Prepare the necessary tools: a Phillips #1 screwdriver, a thin flathead screwdriver or a plastic spudger, a desoldering pump, a soldering station or a soldering iron, a wire cutter.
  2. Gamma Scout Geiger Counter Battery Replacement, Removing the USB port cover: 手順 2、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Removing the USB port cover: 手順 2、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Removing the USB port cover: 手順 2、 3の画像 3
    • Locate the cover of the USB port on the bottom side of the geiger counter.
    • Remove the USB port cover using a thin flathead screwdriver or using a spudger.
  3. Gamma Scout Geiger Counter Battery Replacement, Locating the screws: 手順 3、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Locating the screws: 手順 3、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Locating the screws: 手順 3、 3の画像 3
    • Locate the three screws on the back side of your device.
    • Notice that two of your screws are covered by the serial number sticker.
    • You either have to partially lift up this sticker to get access to the screws, or you can choose to cut two round holes into the sticker.
  4. Gamma Scout Geiger Counter Battery Replacement, Removing the screws: 手順 4、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Removing the screws: 手順 4、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Removing the screws: 手順 4、 3の画像 3
    • Remove the three screws using a Phillips #1 screwdriver.
  5. Gamma Scout Geiger Counter Battery Replacement, Opening the case: 手順 5、 1の画像 1
    • After you have removed all the three screws, the case should easily come apart.
    • For this step you will not need any tools, because the front and back parts of the case will get apart easily.
    • Notice that the PCB will remain attached to the front side of the case, so it is recommended to lift up the back side of the case while holding the device upside-down.
    • Make sure not to touch the upper part of the PCB or the geiger tube, because these parts of the device are under high voltage.
    • Be careful not to hit or touch the front end window of the geiger tube, because it is made out of a very thin and very fragile material.
  6. Gamma Scout Geiger Counter Battery Replacement, Deconnecting the keyboard: 手順 6、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Deconnecting the keyboard: 手順 6、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Deconnecting the keyboard: 手順 6、 3の画像 3
    • To be able to remove the PCB from the case, you will need to disconnect the flat-flex cable that goes to the keys located at the front side of the device.
    • For this step you will need a spudger or a pair of nonconducting pliers, to push off or to pull down the connector from the pin header.
    • This step requires some force to remove the connector from the pin header, but be careful not to tear apart or rip off the connector from the flat-flex cable.
    • If you decide to use a pair of pliers for this step, make sure it is made out of plastic or some other non-conducting material, because it will touch the PCB and it could create a short-circuit.
  7. Gamma Scout Geiger Counter Battery Replacement, Removing the old battery: 手順 7、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Removing the old battery: 手順 7、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Removing the old battery: 手順 7、 3の画像 3
    • After you successfully removed the PCB from the case, the next step is to cut the cable tie that is holding the old lithium battery onto the PCB using a wire cutter.
    • Next you will have to remove the lithium battery from the PCB, by cutting its two terminals that are soldered onto the PCB, with a wire cutter.
    • As an alternative, you also can directly desolder the lithium battery, without cutting its terminals.
    • Make sure not to touch the upper part of the PCB or the geiger tube, because these parts of the device are under high voltage, until the battery is removed.
  8. Gamma Scout Geiger Counter Battery Replacement, Cleaning the solder joints: 手順 8、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Cleaning the solder joints: 手順 8、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Cleaning the solder joints: 手順 8、 3の画像 3
    • Now that the battery is removed, you have to desolder the remaining parts of the battery terminals.
    • After that, you have to clean the solder joints where the two terminals of the battery were soldered onto.
    • For cleaning the solder joints and to remove the remaining solder, you can use a desoldering pump or a solder wick.
    • If you have excess flux residue on the PCB, you can clean it with isopropyl alcohol.
  9. Gamma Scout Geiger Counter Battery Replacement, Installing the new battery: 手順 9、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Installing the new battery: 手順 9、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Installing the new battery: 手順 9、 3の画像 3
    • Now that your solder joints are clean, prepare the new battery by bending its terminals into the desired form.
    • You can also cut down the excess part of the battery terminals to make the insertion easier, but do not cut them too short.
    • After you inserted the battery terminals through the holes of the PCB (observe correct polarity), secure the new battery onto the PCB with a new cable tie.
  10. Gamma Scout Geiger Counter Battery Replacement, Soldering the battery to the PCB: 手順 10、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Soldering the battery to the PCB: 手順 10、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Soldering the battery to the PCB: 手順 10、 3の画像 3
    • Now that your battery is secured onto the PCB with the cable tie, turn the PCB over and start soldering the battery terminals onto the PCB.
    • After the solder joints have cooled down, cut down the excess part of the battery terminals with a wire cutter.
    • Be careful not to make a short-circuit with the wire cutter or with the terminal wire that will fall off after it will be cut down.
  11. Gamma Scout Geiger Counter Battery Replacement, Installing the PCB back into the case: 手順 11、 2の画像 1 Gamma Scout Geiger Counter Battery Replacement, Installing the PCB back into the case: 手順 11、 2の画像 2
    • After you successfully finished the soldering part, you can start to reassemble the geiger counter.
    • To facilitate the reconnection of the flat-flex cable connector to the pin header of the PCB, you can temporarily remove the front glass protection window of the geiger counter, to be able to maneuver and push the connector onto the pin header.
    • After the connector of the flat-flex cable is firmly connected to the pin header, reinsert the front glass protection window and insert the PCB into the case.
  12. Gamma Scout Geiger Counter Battery Replacement, Reassembling the case: 手順 12、 3の画像 1 Gamma Scout Geiger Counter Battery Replacement, Reassembling the case: 手順 12、 3の画像 2 Gamma Scout Geiger Counter Battery Replacement, Reassembling the case: 手順 12、 3の画像 3
    • After the PCB is correctly installed into the front part of the case, close the case carefully by placing the back cover onto it.
    • Insert the three screws into the holes of the back case and screw them in.
    • Because the holes have no metal thread, be careful not to overtighten the screws.
  13. Gamma Scout Geiger Counter Battery Replacement, Resetting the device: 手順 13、 2の画像 1 Gamma Scout Geiger Counter Battery Replacement, Resetting the device: 手順 13、 2の画像 2
    • After you finished the assembly of the case, look for the reset button on the PCB of the geiger counter, located near to the USB port.
    • Push the reset button of the geiger counter with your finger or with a plastic spudger to reset your device to the factory defaults (this step is necessary after battery replacement).
    • Reinsert the USB port cover into the bottom side of the geiger counter.
    • After you set the date and time and configure the datalogging settings, your device is fully functional.
    • Check the battery voltage on the screen of your device.
    • Because geiger counters are test equipments, after a battery replacement you should check the correct function of the device and you should also check the accuracy of the device with a known test source.
ゴール
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Bela Sajgo
メンバー登録日: 12/01/19
475 ポイント
1ガイドが承認済み
18件のガイドコメント
I blew the tube while replacing the cell and the mica window shattered, it was a mild touch, nothing significant, like a thin paper balloon bursting.
Any idea, where i may buy and new tube? The marking on the tube is LND712.
amitra - 返信
https://www.lndinc.com/products/geiger-m...
Depending on the country you live in, you may also find LND712 geiger tubes from local sellers on Ebay.
Bela Sajgo -
Thanks a lot! Worked as described! Ready again for nuclear war :-(
Ales Tomek - 返信
I’m glad it was useful for you!
Bela Sajgo -
Kedves Béla, nagyon jó guide. Viszont nem bízom magamban. Nem tudná megcsinálni nekem (nyilván nem jótékonysági keretek között)? :-)
Norbert Nagy - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 121
今までの合計 8,443
