メインコンテンツにスキップ
Gamestop G3 Gamecube Left and Right Trigger Replacement
必要な工具と部品
  1. Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: 手順 1、 3の画像 1 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: 手順 1、 3の画像 2 Gamestop G3 Gamecube Left and Right Trigger Replacement, Back Panel: 手順 1、 3の画像 3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 2、 3の画像 1 Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 2、 3の画像 2 Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 2、 3の画像 3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 3、 3の画像 1 Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 3、 3の画像 2 Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 3、 3の画像 3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
  4. Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: 手順 4、 2の画像 1 Gamestop G3 Gamecube Left and Right Trigger Replacement, Left and Right Trigger: 手順 4、 2の画像 2
    • Remove the screws holding the plastic bumper cover in place and remove it.
  5. Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 5、 3の画像 1 Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 5、 3の画像 2 Gamestop G3 Gamecube Left and Right Trigger Replacement: 手順 5、 3の画像 3
    • At this point you should be able to remove the bumper along with its spring from the controller.
    • Clean thoroughly underneath the bumper and remove any dirt or debris before reattaching.
    • To reassemble the device, follow these steps in reverse order.
終わりに
作成者
4人の作成者と共同で作成されました。
John Harrison
メンバー登録日: 10/28/16
213 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S3G5
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 327
