メインコンテンツにスキップ
GameStop GS3 GameCube Controller joysticks replacement
必要な工具と部品
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: 手順 1、 2の画像 1 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: 手順 1、 2の画像 2
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: 手順 2、 1の画像 1
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: 手順 3、 3の画像 1 GameStop GS3 GameCube Controller joysticks replacement: 手順 3、 3の画像 2 GameStop GS3 GameCube Controller joysticks replacement: 手順 3、 3の画像 3
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: 手順 4、 3の画像 1 GameStop GS3 GameCube Controller joysticks replacement: 手順 4、 3の画像 2 GameStop GS3 GameCube Controller joysticks replacement: 手順 4、 3の画像 3
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: 手順 5、 3の画像 1 GameStop GS3 GameCube Controller joysticks replacement: 手順 5、 3の画像 2 GameStop GS3 GameCube Controller joysticks replacement: 手順 5、 3の画像 3
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
終わりに
作成者
7人の作成者と共同で作成されました。
Andrew Gonsalves
メンバー登録日: 10/20/16
226 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S3G5
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 31
今までの合計 1,380
