はじめに
Use this guide to remove the battery from your GameSit T4 Pro controller. All you need for this repair is a Phillips #1 screwdriver and the iFixit opening tool. For the battery replacement, this controller requires a 600 maH battery. Complete this repair guide before continuing to the other repair guides.
必要な工具と部品
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
ある他の人がこのガイドを完成しました。
3 件のコメント
Battery Model is pl502450 600mah
3.7v
Where can I buy this battery? Do You have a link to it?
