メインコンテンツにスキップ
Game Boy Pocket LCD Screen Replacement
必要な工具と部品
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: 手順 1、 3の画像 1 Game Boy Pocket LCD Screen Replacement, Remove the external screws: 手順 1、 3の画像 2 Game Boy Pocket LCD Screen Replacement, Remove the external screws: 手順 1、 3の画像 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket LCD Screen Replacement, Open the device: 手順 2、 3の画像 1 Game Boy Pocket LCD Screen Replacement, Open the device: 手順 2、 3の画像 2 Game Boy Pocket LCD Screen Replacement, Open the device: 手順 2、 3の画像 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: 手順 3、 1の画像 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: 手順 4、 3の画像 1 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: 手順 4、 3の画像 2 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: 手順 4、 3の画像 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: 手順 5、 2の画像 1 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: 手順 5、 2の画像 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: 手順 6、 3の画像 1 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: 手順 6、 3の画像 2 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: 手順 6、 3の画像 3
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: 手順 7、 3の画像 1 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: 手順 7、 3の画像 2 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: 手順 7、 3の画像 3
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
終わりに
15 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Adriana Rahrig
メンバー登録日: 10/07/14
1,523 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S1G1
4 メンバー
13のガイドは作成済み
3 件のコメント
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - 返信
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser -
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 65
過去 30 日: 334
今までの合計 22,601
