メインコンテンツにスキップ
Game Boy Headphone Jack Replacement
必要な工具と部品
  1. Game Boy Headphone Jack Replacement, Batteries: 手順 1、 2の画像 1 Game Boy Headphone Jack Replacement, Batteries: 手順 1、 2の画像 2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Headphone Jack Replacement: 手順 2、 3の画像 1 Game Boy Headphone Jack Replacement: 手順 2、 3の画像 2 Game Boy Headphone Jack Replacement: 手順 2、 3の画像 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Headphone Jack Replacement: 手順 3、 2の画像 1 Game Boy Headphone Jack Replacement: 手順 3、 2の画像 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Headphone Jack Replacement, Outer Case: 手順 4、 1の画像 1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Headphone Jack Replacement: 手順 5、 1の画像 1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Headphone Jack Replacement: 手順 6、 1の画像 1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Headphone Jack Replacement: 手順 7、 1の画像 1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Headphone Jack Replacement, Headphone Jack: 手順 8、 2の画像 1 Game Boy Headphone Jack Replacement, Headphone Jack: 手順 8、 2の画像 2
    • The headphone jack is located on the bottom of the rear outer casing, near the battery compartment.
    • Use a Phillips #00 screwdriver to remove the two screws holding the headphone jack in place.
  9. Game Boy Headphone Jack Replacement: 手順 9、 2の画像 1 Game Boy Headphone Jack Replacement: 手順 9、 2の画像 2
    • Once the headphone jack is detached it will dangle by the wires attached to the main circuit board. Do not worry about the connections, they are solid and will not break.
    • Use a Phillips#00 screwdriver to remove the two screws that hold the main circuit board to the casing. This will allow access to the connection points of the headphone jack.
  10. Game Boy Headphone Jack Replacement: 手順 10、 2の画像 1 Game Boy Headphone Jack Replacement: 手順 10、 2の画像 2
    • Use a plastic opening tool to remove the main circuit board from the casing.
    • Once the main circuit board is removed, set aside the outer casing.
  11. Game Boy Headphone Jack Replacement: 手順 11、 3の画像 1 Game Boy Headphone Jack Replacement: 手順 11、 3の画像 2 Game Boy Headphone Jack Replacement: 手順 11、 3の画像 3
    • Desolder the four wires connecting the headphone jack to the motherboard.
    • Desolder the four wires connected to the headphone jack
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Remove the headphone jack with tweezers.
終わりに
16 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Andrew Tramposch
メンバー登録日: 06/24/10
2,243 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S3G2
3 メンバー
34のガイドは作成済み
コメント 1 件
Hi, great work, but where could I find replacement to buy?
Thanks
fred fred - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 36
過去 30 日: 127
今までの合計 18,528
